1989 Chevy Truck
JEFFREY SCOTT
  • 1989 CHEVROLET TRUCK
1989 Chevy Truck
1989 chevy 1500 4.3 5 speed manual. New starter good battery solid connections will not start it seems like the starter is not getting proper voltage when starting it cliicks and turn engine 1 half turn I know moter runs fine it will push start easily
Do you
have the same problem?
Saturday, May 17th, 2008 AT 3:27 PM
LEGITIMATE007
  • EXPERT
Try to jump start it with another vehicle. That;ll tell us right there if its not getting enough juice to start it
Saturday, May 17th, 2008 AT 3:36 PM
Look for power at the purple wire on the starter solenoid not there jumper the clutch switch try to start it-nothing test the ignition switch
See below starter circuit-
http://www.2carpros.com/forum/automotive_pictures/12900_starter1_5.jpg
Recommended Guides
