Brake light on dash?
CHASMAR04
  • 1992 CHEVROLET TRUCK
  • 6 CYL
  • MANUAL
  • 240,000 MILES
Brake light on dash blinks 3 times and then on solid then it repeats?
Sunday, November 22nd, 2009 AT 2:30 PM
DR LOOT
  • 2,311 POSTS
This is telling you there is a problem with the ABS system must likely a wheel speeds sensor here is a video that shows how to get the codes.
https://youtu.be/rTtAnsOlZU4
Please let us know what you find.
Friday, November 27th, 2009 AT 6:07 PM
STENNY
  • 13 POSTS
  • 5.7L
  • V8
  • 4WD
  • 150,000 MILES
Dash brake light comes on sometimes so I checked parking brake and when I push down parking brake light gets brighter so its not because of the parking brake. Not sure what woukd cause that to come one every so often.
Wednesday, January 30th, 2019 AT 11:38 AM (Merged)
CARADIODOC
  • 33,742 POSTS
Brilliant! You are the first person to recognize the change in brightness as a clue. There's at least one and usually two other switches that also turn on the red "Brake" warning light. One is a Low Fluid switch in the brake fluid reservoir. If the fluid is low, either there's a leak or the front brake pads are worn down and ready to be replaced. Don't fill the reservoir. Add just enough clean brake fluid to turn the light off, then have the brake system inspected. Be very careful to not get any petroleum-based contaminants in the brake fluid. That will turn into a real expensive repair.
The other switch is on the combination valve. Follow the two steel brake lines from the master cylinder to that valve right below it on the frame rail. There's a single wire plugged into it. Unplug that wire. If the light goes out, unequal pressures are building up in the two hydraulic systems. That's due to a leak that we have to find.
SPORK
  • 1989 CHEVROLET TRUCK
I have a 1989 chevy c1500 305 auto tranny 300000 miles tbi my brake warning light is solid then 5 short flashes then solid whats this mean please and thanks
EDI3000
  • 34 POSTS
Turn on the ignition. Jumper pins A & H on the data link connector. A is top right, and pin H second from left bottom row. Then count the flashes. Then tell me how many flashes.
BILLK
  • 16 POSTS
  • 1990 CHEVROLET TRUCK
  • 89,000 MILES
K1500 rwal brakes. Replaced the drums (adjusted the brakes as best as can), and right rear ebrake cable. Warning light is on bright when ebrake is applied and stays on dim when ebrake is released. Master cylinder is full and no sign of leak. Light was not on prior to doing above work. Any help if diagnosing and repairing problem will be appreciated.
Thank you,
Bill
HMAC300
  • 48,601 POSTS
If the brake light is on, have it scanned for abs codes and checked for a hydraulic problem
KHLOW2008
  • 41,815 POSTS
Seems a fault with the ABS system is causing this.
Check the wheel sensors.
BILLK
  • 16 POSTS
Thank you for your help-problem was the combination valve needed to be centered and light reset.
Bill K
KHLOW2008
  • 41,815 POSTS
Glad to know you have the problem fixed.
Have a nice day.
Wednesday, January 30th, 2019 AT 11:39 AM (Merged)
