A/C, heater fan not working
DEANNM
  • CHEVROLET TRAILBLAZER
I have a 2005 trailblazer. It has a front ac/heater fan and a rear one. The had completely quit blowing any air form the ac, heater and defrost. My back one still works fine. Can you please tell me why what may have quit working to cause this? Can you also tell me the part I would need to replace. My warrenty is up by just 6000 miles.
Do you
have the same problem?
Tuesday, September 11th, 2007 AT 12:27 PM
MERLIN2021
  • EXPERT
This system, especially if auto temp control, is quite complicated to test even with the right scantool, if you have a warrantee, don't walk, RUN to the shop.
Tuesday, September 11th, 2007 AT 12:54 PM
JACK42
If you cant hear the blower motor, start by checking all fuses. Then use a test light to check for power at the blower motor when it is turned on, in all fan speed positions. If there is power but no blower, then the motor is bad.
Tuesday, September 11th, 2007 AT 2:02 PM
Recommended Guides
