2004 Chevy Trailblazer after I sevice it
WOODY242
  • 2004 CHEVROLET TRAILBLAZER
  • 6 CYL
  • AWD
  • 51,111 MILES
I notice that the service engine soon light an change oil light was comin on the dash board, so I change the spark plugs an change the oil now the car is losing power an cutting off while its idle an when I turn on the ac it loses power an cuts off. At first I thought I might hane put in the spark plugs the wrong way so I took them out an did them again but its still cutting off an losing power while its idle
Do you
have the same problem?
Sunday, June 8th, 2008 AT 10:26 PM
BLACKOP555
  • EXPERT
Make sure you used the proper plugs for one, make sure the gaps are properly set, not all pregapped plugs are set right.
Thirdly did you do one at a time as to avoid mixing up the plug wires? Make sure the wires are secure on the plugs and on the distributor cap.
Hows the oil level?
And make sure you didnt unhook anysensors when messign with the plugs, it happens.
Monday, June 9th, 2008 AT 7:52 AM
Recommended Guides
