Why would air not blow through the vents in the dash, but will blow through the defrost and floor vent?
Tuesday, July 5th, 2011 AT 11:20 AM
HMAC300
MECHANIC
Because one or both of the actuators on the hvac unit aren't working right. They could be stuck or not working at all. Trailblazers were also notorious for the control head going bad. I'll send a generic pic of a hvac so you can see where the actuator is.
Image (Click to make bigger)
SPONSORED LINKS
Wednesday, August 23rd, 2017 AT 4:31 PM
DBOOGIE
MEMBER
2004 CHEVROLET TRAILBLAZER
71,000 MILES
Recently my front vents stopped working on my 2004 Chevy Trailblazer. I've tried to recalibrate by taking out the fuse, waiting a couple minutes, putting the fuse back in, turning the car to run, letting it go through its motions, but that didn't work. The air blows cold, but it is only coming out at the feet, side vents and defrost. Do you know what could be the cause?
Saturday, June 20th, 2020 AT 10:49 AM
(Merged)
PROMECHANIC
MECHANIC
It sounds like you have a mode door actuator that has gone out. Here is a guide that will show you which actuator to replace with diagrams below to show you on your car.
You can try: Turning your key on and pull fuse 39 under the rear seat. Wait for a minute and put it back in. Let it sit for couple of minutes and restart the engine, might be good to go. Here is what it will be like on your car. Please let us know what happens. Cheers,
(Merged)
DBOOGIE
MEMBER
Ok, thanks for your help! I will try that!
Saturday, June 20th, 2020 AT 10:50 AM
(Merged)
PAULCOBBLE
MEMBER
1 POST
We have a 2005 trailblazer that has been having the same problem. We took it back 2 different times within the first year for the same thing. Amazingly when we took it this time they was able to tell me what the problem was. When they took it to the shop to check it the A/C was working correctly. When they called us to tell us what was wrong with it, they said that when it has a problem like that it saves the code. He said that the actuator needed to be replaced $250. When we got back to pick it up I asked why they couldn't get the code like that when we brought it in for that 6 yrs ago. He couldn't give me an answer.
SPONSORED LINKS
(Merged)
BIBLIA23
MEMBER
1 POST
4WD
AUTOMATIC
My air conditioner only blows the air through defrost or bottom vents, but none through the front, what could it be?
(Merged)
FIXITMR
MECHANIC
When you select center what happens?
(Merged)
WRENCHTECH
MECHANIC
The mode doors are controlled by an electric actuator mounted on the driver's side of the HVAC unit under the dash. The actuator may be bad or the linkage may just be stuck.
(Merged)
KELLY SELTZER
MEMBER
1 POST
6 CYL
2WD
AUTOMATIC
169,900 MILES
The air conditioner is blowing cold and hot at the same time, cold on every vent besides the passengrer side. The air is cold so I know it is not the freon
(Merged)
HMAC300
MECHANIC
There is a blend door in your heater and it's either stuck or not working. It 's electrical or vacuum. You can reach your hand under the dash and see if you can move it one way or the other. You should be able to see if it will start to put the pass vent cold or not.
(Merged)
DTLAXSON
MEMBER
1 POST
V8
2WD
AUTOMATIC
60,000 MILES
My problem is the dual electronic controls work on all but the top vents when in that mode. Also when the unit is off it still blows on the floor. Thanks Troy
(Merged)
2CARPRO JACK
MECHANIC
Does it still blow (fan on) or is it just outside air getting in? Pretty sure those are a constant air circulation truck, there is always air coming in. The controller wont switch to the dash vents?
SPONSORED LINKS
(Merged)
ELIZABETH CIANO
MEMBER
1 POST
2003 CHEVROLET TRAILBLAZER
6 CYL
2WD
AUTOMATIC
176,000 MILES
Where is the fan speed resistor located?
(Merged)
DOCFIXIT
MECHANIC
Behoind glove box in air plenum just left of blower motor
