2003 Chevy Trailblazer AC works when engine starts cool
Air Conditioning problem
2003 Chevy Trailblazer 6 cyl Two Wheel Drive Automatic 64000 miles
When my car is in the garage and I leave and turn on the aC it works fine. BUT when my car is out in the sun and is hot and I start it up then the AC blows hot air. I just took it to an auto repair and they charged me $1200 to replace the compressor. But it is still doing the same thing! I took it back and they said that maybe there is a leak and bring it back and they will check. My question - was it REALLY the compressor that was bad OR is there another part that needs to be replaced? I hate to pay $1200 if it is really just a $50 part that needed replaced.
Do you
have the same problem?
Thursday, June 10th, 2010 AT 4:23 PM
If it is doing the same thing as before the compressor was replaced, I would say that the compressor may not have been needed, but I don't know all the circumstances. Does the system operate still, or has it gone completely non-functional. If it still operates satisfactorily at times, I doubt you have a leak. There is a bulletin for an intermittently faulty low pressure switch. It gives some diagnostics that you may be able to do, first you have to locate the switch. I believe it is on the accumulator. Here is the bulletin for your reference.
03-01-39-007: Air Conditioning (A/C) Inoperative/Intermittent, A/C Blows Warm Air (Replace A/C Low Pressure Cycling Switch) - (May 29, 2003)
Subject: Air Conditioning (A/C) Inoperative/Intermittent, A/C Blows Warm Air (Replace A/C Low Pressure Cycling Switch)
Models: 2003 Cadillac Escalade, Escalade EXT, Escalade ESV
2002-2003 Chevrolet TrailBlazer, TrailBlazer EXT
2003 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2002-2003 GMC Envoy, Envoy XL
2003 GMC Sierra, Yukon, Yukon XL
2002-2003 Oldsmobile Bravada
2003 HUMMER H2
Some customers may comment that the A/C system is intermittently inoperative or blows warm air.
An intermittent inoperative (open) A/C low pressure cycling switch may be the cause. This is an intermittent condition and temperatures may play a critical role if the vehicle is in the failed mode or operating as designed.
Follow the diagnosis and service procedure below to correct this condition.
Park the vehicle inside or in the shade.
Open the windows in order to ventilate the interior of the vehicle.
If the A/C system was operating, allow the A/C system to equalize.
Turn OFF the ignition.
Open the hood and install fender covers.
" Avoid breathing the A/C Refrigerant 134a (R-134a) and the lubricant vapor or the mist. Exposure may irritate the eyes, nose, and throat. Work in a well ventilated area. In order to remove R-134a from the A/C system, use service equipment that is certified to meet the requirements of SAE J 2210 (R-134a recycling equipment). If an accidental system discharge occurs, ventilate the work area before continuing service. Additional health and safety information may be obtained from the refrigerant and lubricant manufacturers.
" For personal protection, goggles and gloves should be worn and a clean cloth wrapped around fittings, valves, and connections when doing work that includes opening the refrigerant system. If R-134a comes in contact with any part of the body severe frostbite and personal injury can result. The exposed area should be flushed immediately with cold water and prompt medical help should be obtained.
" R-134a is the only approved refrigerant for use in this vehicle. The use of any other refrigerant may result in poor system performance or component failure.
" To avoid system damage use only R-134a dedicated tools when servicing the A/C system.
" Use only Polyalkylene Glycol Synthetic Refrigerant Oil (PAG) for internal circulation through the R-134a A/C system and only 525 viscosity mineral oil on fitting threads and O-rings. If lubricants other than those specified are used, compressor failure and/or fitting seizure may result.
" R-12 refrigerant and R-134a refrigerant must never be mixed, even in the smallest of amounts, as they are incompatible with each other. If the refrigerants are mixed, compressor failure is likely to occur. Refer to the manufacturer instructions included with the service equipment before servicing.
Install the J 43600 ACR 2000 Air Conditioning Service Center.
" The ambient temperature must be at least 16 C (60 F) .
" Do not induce additional air flow across the front of the vehicle during the test.
Record the ambient temperature displayed on the J 43600.
Record readings of the low and high side STATIC pressures. The pressures should be within the specifications listed below.
" Above 16 C (60 F): 345 kPa (50 psi)
" Above 24 C (75 F): 483 kPa (70 psi)
" Above 33 C (90 F): 690 kPa (100 psi)
" If the static pressures are within specification, continue with Step 12.
" If the static pressures are NOT within specifications, refer to Leak Testing (SI Document ID# 1141201).
Apply the parking brake.
Place the transaxle/transmission in PARK.
Start the engine.
Turn on the A/C system.
Inspect the A/C compressor to see if it is operating properly.
If the compressor is not operating as designed, tap on the low pressure cycling switch (2) with a small hand tool. The compressor should start operating correctly.
If the compressor does not operate correctly after tapping on the low pressure cycling switch (2), disconnect the switch and jumper the lower pressure cycling switch connector with a fused jumper. If the compressor still does not operate properly, refer to HVAC Compressor Clutch Does Not Engage diagnostic in SI.
Important: DO NOT USE A/C low pressure cycling switch, P/N 15035084 on the vehicles listed above.
If the compressor does operate correctly after tapping on the switch or jumping the low pressure cycling switch connector, replace the low pressure cycling switch (2), P/N 89040362. Refer to Air Conditioning (A/C) Low Pressure Switch Replacement in SI.
Perform the Air Conditioning (A/C) System Performance Test in SI.
Disconnect the J 43600 ACR 2000 Air Conditioning Service Center.
Remove the fender covers and close the hood.
Parts Information
Important: Only a small quantity of parts are available. Please DO NOT order for stock only.
Part Number
Switch, Pressure Cycling
Parts are currently available from GMSPO.
Friday, June 18th, 2010 AT 10:19 PM
Recommended Guides
