2002 Chevy Trailblazer Brakes
HEK
  • 2002 CHEVROLET TRAILBLAZER
  • 6 CYL
  • 150,000 MILES
I have a '02 Trailblazer in which the brake lines running from the master cylinder to the proportional valve broke and got replace. Now theres very little to no brake fluid running to the the rear wheels and the calipers dont seem to be tightening at all. Ive tried bleeding the air out of the lines through the bleed screws but there was no brake fluid coming out. I was told that it may have something to do with a fuse or something. Can someone help me with this?
Do you
have the same problem?
Thursday, May 6th, 2010 AT 8:25 PM
BMRFIXIT
  • EXPERT
Air in the master cylinder start by pumping and bleeding master cylinder and then go to rear right tire and bleed it, left rear, right front and left front
Friday, May 7th, 2010 AT 8:22 PM
