I need a diagram of the install of plug wires for a 97 tahoe
Sunday, March 29th, 2009 AT 5:03 PM
BMRFIXIT
MECHANIC
You need the firing order this is for the 5.7L and 7.5L Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
SPONSORED LINKS
Monday, March 30th, 2009 AT 8:02 PM
COREY H JENKINS
MEMBER
1996 CHEVROLET TAHOE
5.7L
V8
4WD
AUTOMATIC
250,000 MILES
Replaced head gasket on SUV.
Putting it all back together with only one problem, my son helped me. He pulled plug wires off distributor cap without marking them. They still attached onto spark plugs. Could you show me a diagram of how they go back. Please and thank you
Thursday, February 18th, 2021 AT 5:23 PM
(Merged)
SATURNTECH9
MECHANIC
I posted a diagram of the cylinders and where the go on the distributor.
Image (Click to make bigger)
(Merged)
COREY H JENKINS
MEMBER
Thank you for a quick reply
My distributor cap is more squared off than round and coil wire is not in middle. Enclosing a picture of cap.
Also, which side would the coil wire hookup go on passenger or drivers?
(Merged)
SATURNTECH9
MECHANIC
I am sorry I posted the wrong diagram the one I just posted here for you is the correct one with the cap you have.
SPONSORED LINKS
(Merged)
COREY H JENKINS
MEMBER
You guys are a lifesaver as always.
(Merged)
SATURNTECH9
MECHANIC
You are welcome. Please tell all your friends about us and thank you for using 2carpros.
(Merged)
CONNMANN68
MEMBER
V8
4WD
AUTOMATIC
200,000 MILES
Just the passenger side is all disconnected. Illustration would be nice if possible.
(Merged)
JDL
MECHANIC
The passenger side cylinder bank, from front to back, the cylinders are numbered 2468.
The distributor cap, passenger side, front to back, 8246.
The firing order is 18436572, the rotor turns clockwise. This is for a 5.7L engine.
Maybe somebody else can post a picture, I can't.
(Merged)
MAELSTROM669
MEMBER
1995 CHEVROLET TAHOE
5.7L
V8
2WD
AUTOMATIC
183,000 MILES
I've seen two different 'standard' diagrams for the spark plug-to- distributor wiring layout at the distributor cap.
One seems logical, and follows firing order, the other doesn't seem to match up, unless the rotor skips when it conducts. I'm confused, and need to know which diagram is right.
Images (Click to make bigger)
(Merged)
DANNY L
MECHANIC
Hello, I'm Danny.
The second picture you attached is correct (below). Hope this helps and thanks for using 2CarPros.
Danny-
(Merged)
MAELSTROM669
MEMBER
Thank you very much, Danny.
SPONSORED LINKS
(Merged)
DANNY L
MECHANIC
You're welcome !
Hope you will use us again in the future. Thanks again for using 2CarPros.
Danny-
(Merged)
ASILOS
MEMBER
1 POST
1979 CHEVROLET TAHOE
Where is the #1 spark plug wire for a 1979 Chevy Suburban?
Thursday, February 18th, 2021 AT 5:24 PM
(Merged)
DANCESWITHWOLVES49
MEMBER
I should have stated more clearly. Since the firing order is clokwise then the number 1 Plug will be the first one to the left of the window on the distributor. The firing order is stil the same 1-8-4-3-6-5-7-2.
(Merged)
MECHANIC
Ok 1st shirt
Sitting at your normal driving positon its on the left 1st plug then 3, 5, 7 left bank Right bank2, 4, 6, 8 and then take it clockwise.I start at 12 o clk then follow it all the way.
HHT 4 Sqdn 7 Air Cav 1977-78
Sqdn Tac Comm Chief
Camp Rice/Garry Owen
BTW are they still there-We're the baddest of all in the Indian Tribes 2ID in the Western Corridor during my time. PRT we take it all the way to Camp Stanton and Back with no problems with flash lights. Every Morning or we take it to Moonsan. HQ Camp Casey TDC
(Merged)
DANCESWITHWOLVES49
MEMBER
You are correct, 1-3-5-7 are the left bank when in the drivers seat and #1 is the front cylinder. At the distributo, r find the window, and as you are looking at the window, #1 SHOULD be the one to the left of the window then 8-4-3-6-5-7-2 going CLOCKWISE from #1. Not sure about the modern day 7th Cav.I'm 1st Sgt of Company F. Horse cavalry. My CO is G. A. Custer Lt. Col. Bvt Major General. Lololololol I'm a retired SSG (24 years) but now do the reenactment of Little Big Horn
