2008 Chevy Tahoe Oil burning smell
Smells problem
2008 Chevy Tahoe V8 Four Wheel Drive Automatic 742 miles
I recently purchased a new 08 chevy Tahoe LTZ. I have had it back to the dealer twice. Once for the tires and a oil burning smell after coming off from the highway through the vents when heater/ac running. There is no signs of any oil dripping or oil stains after being parked over night. After bringing it to the dealer they informed me it was from labels on the manifold. They said they removed them and the smell went away. I then drove the vehicle for a short trip on the highway and noticed the smell was not as strong. I just drove the vehicle to the airport from my house which is 45 minutes away. Upon exiting the highway I noticed the smell again and it appeared to be the same as the first time. They had mentioned there was another lable on the CAT but they did not want to remove it due to the thin covering.
I am writting to see if you have heard of anything that may be causing this issue. I spent a lot on a vehicle that I have not yet enjoyed due to the issues I have had.
Do you
have the same problem?
Monday, November 17th, 2008 AT 5:07 PM
  • 3,149 POSTS
Hello -
First congrats on your new vehicle.....I bet it's nice. I just want to make sure we are on the same vehicle; I am looking at the Tahoe 4WD with a 5.3L engine, not the 6.0L Hybrid engine. If this isn't it let me know which engine.
Based off of what you said new vehicles do have labels etc everywhere. Try turning your AC on inside air circulation air only, not outside air and see if the odor goes away. If so then it may be due to the labels etc.
I reviewed about 167 Technical Service Bulletins on this vehicle and only found one dealing with odor from the vents. So either there hasn't been enough complaints or it only happens to a few vehicles.
I have attached the TSB on odor for your review.
Also, I have attached several Recalls that may apply to your vehicle that the dealer may repair for free. Please get with the service department and provide your VIN number to them to see if they apply to you.
Last, you are correct; you paid a lot for this. It is still under warranty so give it a little time to wear/break in. If you are still not satisfied, get back with them
A/C - Odors In Hot/Humid Conditions
Bulletin No.: 99-01-39-004B
Date: May 29, 2007
Air Conditioning Odor (Install Evaporator Core Dryer Kit and Apply Cooling Coil Coating)
1993-2008 GM Passenger Cars and Trucks (Including Saturn)
2008 and Prior HUMMER H2, H3
All Equipped with Air Conditioning
This bulletin is being revised to update the vehicle applications, model years, correction procedure, parts information and tool numbers. Please discard Corporate Bulletin Number 99-01-39-004A (Section 01 - HVAC).
Some customers may comment about musty odors emitted from the Heating, Ventilation and Air Conditioning (HVAC) system at vehicle start-up in hot, humid conditions.
This condition may be caused by condensate build-up on the evaporator core, which does not evaporate by itself in high humidity conditions. The odor may be the result of microbial growth on the evaporator core. When the blower motor fan is turned on, the microbial growth may release an unpleasant musty odor into the passenger compartment.
There are several other possible sources of a musty odor in a vehicle. A common source is a water leak into the interior of the vehicle or foreign material in the HVAC air distribution system. Follow the procedures in SI for identifying and correcting water leaks and air inlet inspection.
The procedure contained in this bulletin is only applicable if the odor source has been determined to be microbial growth on the evaporator core inside the HVAC module.
Many vehicles currently incorporate an afterblow function within the HVAC control module software. The afterblow feature, when enabled, employs the HVAC blower fan to dry the evaporator after vehicle shut down and this function will inhibit microbial growth. Technicians are to confirm that the customer concern is evaporator core odor and that the vehicle has the imbedded afterblow feature, as defined in the SI document for that specific vehicle model, model year and specific HVAC option. Refer to SI for enabling the afterblow function. Vehicles being delivered in areas prone to high humidity conditions may benefit from having the afterblow enabled calibration installed prior to any customer comment.
If the vehicle is not factory equipped with the imbedded afterblow enable feature, it may be added with the Electronic Evaporator Dryer Module Kit (P/N 12497910 or AC Delco 15-5876).
When installing the Electronic Evaporator Dryer Module, you MUST use the included electrical splice connectors to ensure a proper splice. Complete detailed installation instructions and self testing procedures are supplied with the kit. If necessary, the Electronic Evaporator Dryer Module may be installed underhood if it is protected from extreme heat and water splash areas.
To immediately remove the evaporator core odor on all suspect vehicles, it is necessary to eliminate the microbial growth and prevent its re-occurrence. To accomplish this, perform the following procedure:
Vehicle and Applicator Tool Preparation
The evaporator core must be dry . This may be accomplished by disabling the compressor and running the blower fan on the recirc heat setting for an extended period of time.
Note: Compressor engagement will cause the evaporator core to remain wet and will prevent full adherence of the Coiling Coil Coating to the evaporator core surfaces.
Verify that the air conditioning drain hose is not clogged and place a drain pan beneath the vehicle. Place a protective cover over the carpet below the evaporator core.
Remove the cabin air filter, if equipped, and cover the opening prior to applying the Cooling Coil Coating, as the product may clog the filter. If the cabin air filter appears to have little or no remaining life, suggest a replacement to your customer.
If the HVAC module has a blower motor cooling tube, be careful NOT TO SPRAY THE COOLING COIL COATING INTO THE BLOWER MOTOR COOLING TUBE.
Attach the Flexible Applicator Pressure Spray Tool (J-43810-20A) to a compressed air line operating at 586 kPa (85 psi) to 793 kPa (115 psi).
Shake the bottle of Cooling Coil Coating well. Screw the bottle onto the cap on the applicator tools pick-up tube.
NOTE: The pick-up tube is designed for 120 ml (4 oz) and 240 ml (8 oz) bottles and should coil slightly in the bottom of a 120 ml (4 oz) bottle.
Use one of the following three methods to apply the Cooling Coil Coating.
If the Pressure Applicator Spray Tool (J-43810-20A) is not available, the Cooling Coil Coating is also available in an aerosol can (P/N 12377951 (in Canada, 10953503)).
Application Through Blower Motor Control Module Opening
Remove the blower motor control module (blower motor resistor). Refer to the applicable procedure in SI.
Clean any debris or foreign material from inside the HVAC module and on the evaporator core surface.
Apply the Cooling Coil Coating directly to the evaporator core through the blower motor blower motor control module (blower motor resistor) opening.
Use the flexible wand to direct the Cooling Coil Coating over the entire evaporator core and surrounding gasket surfaces.
When the application is complete, install the blower motor blower motor control module (blower motor control module).
Application Through Blower Motor Opening
Remove the blower motor. Refer to the applicable blower motor removal procedure in SI.
Apply the Cooling Coil Coating directly to the evaporator core through the blower motor opening.
When the application is complete, install the blower motor.
Application Through a Hole in the HVAC Module
If neither of the two previous application methods are available, it may be necessary to drill a hole in the HVAC module.
Locate an area of the HVAC module between the blower motor and the evaporator core. Drill a 10 mm (3/8 in) hole in the HVAC module. Use caution to keep the drill clear of the evaporator core and the blower motor fan.
With the air distribution vents closed and the blower motor fan speed on HIGH, insert the applicator tool into the hole and spray the Cooling Coil Coating into the airstream toward the evaporator core.
Use a GM approved RTV sealant to plug the hole in the HVAC module.
After the Cooling Coil Coating application is complete, start and run the vehicle for approximately 10 minutes, with the compressor disabled, HVAC mode set to Recirculate/Max, heat set to full warm, blower motor fan speed on high, and one window open approximately 12 mm (1/2 in). This cures the Cooling Coil Coating onto the evaporator core surface.
While the engine is running, rinse the applicator tool with warm water to prolong the life of the tool. Be sure to spray warm water through the nozzle to rinse out any residual Cooling Coil Coating still in the capillary pick up tube, otherwise it will dry and clog the applicator tool. Also remove the small green valve from the bottle cap and rinse it thoroughly while rolling it between two fingers and then reinstall it. If this valve is clogged the Cooling Coil Coating will not flow through the applicator tool.
Shut off the engine and enable the compressor again.
Verify proper HVAC system operation.
Remove the protective cover from inside the vehicle.
Remove the drain pan from underneath the vehicle.
Reinstall the cabin air filter if necessary
Monday, November 17th, 2008 AT 5:44 PM
Recommended Guides
