2004 Chevy Tahoe Wont Start
GORDONJONES
  • 2004 CHEVROLET TAHOE
  • V8
  • 4WD
  • 50,000 MILES
Engine wont start. Cranks but will not start
Do you
have the same problem?
Sunday, November 23rd, 2008 AT 12:21 PM
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, November 23rd, 2008 AT 12:25 PM
Recommended Guides
