2003 Chevy Tahoe replacing the fuel pump on a Flex vinz V8
ALBATE
  • 2003 CHEVROLET TAHOE
  • V8
  • 4WD
  • 60,000 MILES
I would like to know how to replace my fuel pump on my 2003 chevy tahoe flex vinZ where it is located and how do I replace it. Any help with this would be greatly appreciated.
Thank You
Do you
have the same problem?
Friday, June 11th, 2010 AT 7:08 PM
Hi,Welcome to 2carpros and TY for the donation.
Component Locations
http://www.2carpros.com/forum/automotive_pictures/12900_fpl1_1.jpg
http://www.2carpros.com/forum/automotive_pictures/12900_fpl2_1.jpg
Fuel Sender Assembly Replacement
Tool Required
J44402 Fuel Tank Sending Unit Wrench.
Removal Procedure
http://www.2carpros.com/forum/automotive_pictures/12900_fp1_31.jpg
1.Remove the fuel tank.
2.Disconnect the fuel lines from the sending unit, if necessary.
3.Using J 44402 , remove the sending unit lock ring.
http://www.2carpros.com/forum/automotive_pictures/12900_fp2_13.jpg
4.Remove the lock ring, sending unit, and rubber seal. Discard the seal.
5.Clean the sending unit sealing surfaces.
Installation Procedure
http://www.2carpros.com/forum/automotive_pictures/12900_fp2_14.jpg
Important: The fuel pump strainer must be in a horizontal position when the sending unit is installed in the tank. When installing the sending unit, assure that the fuel pump strainer does not block full travel of the float arm.
1.Install the sending unit and a NEW rubber seal. Align the alignment tab to the correct location on the fuel tank.
2.Using J 44402 , install the sending unit lock ring.
3.Connect the fuel lines to the sending unit, if necessary.
4.Install the fuel tank.
http://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Saturday, June 12th, 2010 AT 4:29 AM
Recommended Guides
