2003 Chevy Tahoe ABS LIght Stays On Code C0222
NOSWEATMAN
  • 2003 CHEVROLET TAHOE
  • V8
  • 4WD
  • 64,671 MILES
When driving the brakes work fine but it feel like they let off pressure when when they are applied. When I first noticed the problem you had to slam on the breaks to engage them but after bleeding the brakes it has helped some. The only code I can find with the OBD II is C0222. The is nothing in the cluster message center. The only sign is the ABS light stays on.
Do you
have the same problem?
Sunday, November 8th, 2009 AT 8:15 AM
BRIAN 1
Measure the resistance at the wheel speed sensor, should be between 700 and 10,000 ohms. If its higher or lower than spec replace the wheel speed sensor.
Sunday, November 8th, 2009 AT 11:22 AM
