1999 Chevy Tahoe WILL NOT START WHEN RAINS
BSUDA77
  • 1999 CHEVROLET TAHOE
Engine Performance problem
1999 Chevy Tahoe V8 Two Wheel Drive Automatic
TRUCK WON'T START WHEN IT RAINS OR DAMP OUTSIDE. BUT WHEN SUN IS OUT LATER IT STARTS FINE. I CHANGED DISTRIBUTOR CAP, PLUGS, WIRES, FUEL & AIR FILTERS, AND FUEL PUMP WORKS FINE.
Do you
have the same problem?
Tuesday, July 14th, 2009 AT 9:31 PM
  • EXPERT
It sounds like you have already replaced the most common problems relating to this. However, have you checked to see if the coil is shorting? At night, start the engine, open the hood, and spray a light mist of water on the ignition system. Do it slowly so you can determine what causes the engine to die. Also, chances are you will see something spark / short causing the engine to die. My guess is the coil.
Thursday, July 16th, 2009 AT 10:19 PM
Recommended Guides
