1999 Chevy Tahoe fuel pump
EO1
  • 1999 CHEVROLET TAHOE
Engine Performance problem
1999 Chevy Tahoe V8 Four Wheel Drive Automatic
how to replace fuel pump. Is there a fuel cut off switch or relay?
Do you
have the same problem?
Thursday, January 15th, 2009 AT 8:29 AM
S1CAPONE
The fuel pump is located inside the gas tank, you have to unhook the rubber hose (there may be 2 a big one and a smaller one) connected to the refuel nozzel, drop the gas tank, unhook the wires (a plug or 2) unscrew the ring that holds the fuel pump down inside of the tank, remove fuel pump up out of the gas tank. Fairly simple job as long as you have the tools to knock it out!
Thursday, January 15th, 2009 AT 1:44 PM
Recommended Guides
