1999 Chevy Tahoe fuel problems
UPFRONTDUCK
  • 1999 CHEVROLET TAHOE
  • V8
  • 4WD
  • 168,000 MILES
I replaced the fuel pump, filter and fuel pump relay on my tahoe and if I prime the intake with fuel it starts and runs until that fuel runs out. The fitting in the line to the intake to hook a manual guage to has no pressure, I can here the pump come on for just a couple seconds and then it doesnt come on any more? Help
Do you
have the same problem?
Thursday, July 16th, 2009 AT 8:21 AM
BMRFIXIT
  • EXPERT
With key on engine off you hear pump coming on
you should have fuel pressure if not suspect bad fuel pump or supply lines
check fuel filter too
Thursday, July 16th, 2009 AT 8:34 AM
UPFRONTDUCK
Installed new pump new filter new pump relay still no pressure at line going into cpi box
Thursday, July 16th, 2009 AT 8:37 AM
THUNDER123
Are you sure you got the flow turned the right way on the filter
Monday, April 15th, 2019 AT 1:54 AM
Recommended Guides
