1999 Chevy Tahoe ABS
BIG AL
  • 1999 CHEVROLET TAHOE
  • V8
  • 4WD
  • 79,988 MILES
IN DRY WEATHER, MY ABS BRAKE MOTOR / SYSTEM COMES ON MOST OF THE TIME. WHY?
Do you
have the same problem?
Monday, November 10th, 2008 AT 6:28 PM
JASONRAY
There may be a problem with one of the wheel speed sensors. If they're reading more than 2 or 3 mph difference, the ABS system will think one wheel is locking up and activate the system. You'll need a scanner to access this information in the PCM. Also, check for codes in the PCM. It may indicate which sensor or what the problem is. Get back with me if you need help.
Monday, November 10th, 2008 AT 6:41 PM
Recommended Guides
