1999 Chevy Tahoe 99 Tahoe brakes spongy at low speed
BCURRAN75
  • 1999 CHEVROLET TAHOE
  • V8
  • 4WD
  • 107,000 MILES
I have a 99 tahoe and when I brake a low speed or come to a stop the brake pedal starts to get soft and the abs comes on. I just replaced both front right and left abs sensors, and I'm still having the same problem.
With the truck off and pumping the brakes it does not seem like the pedel is getting as stift as it should. With the truck running I have a soft pedel almost to floor, and I don't see a leaks anywere.
The brake pads a good front and back and were not done recently.
Any tips
Thanks
Do you
have the same problem?
Friday, January 2nd, 2009 AT 9:00 PM
BUDDYCRAIGG
  • EXPERT
Failing master cylinder
Friday, January 2nd, 2009 AT 9:05 PM
Recommended Guides
