1999 Chevy Tahoe
JOSEPHDADKINS
  • 1999 CHEVROLET TAHOE
Engine Performance problem
1999 Chevy Tahoe V8 Four Wheel Drive
my tahoe runs real ruff at low rpm's runs smooth at 2000 rpm's or higher, I put new wires, plugs, dist, ignithion is firing, its on time, ekg valve is open. Tighthened intake, checked vacume lines, seem ok? Only saw two on intake? What next?
Do you
have the same problem?
Thursday, December 17th, 2009 AT 3:09 PM
PEAR69
What is the fuel pressure. What intake bolts did you tighten? If you are talking about the lower intake bolts (the ones that bolt into the head) I hope you didn't tighten them over 135 INCH pounds -- that is around 10 foot pounds. (VERY LITTLE). The upper intake bolts (the ones that hold the plastic cover on) torque should be even less -- 88 INCH pounds or around 6 foot pounds.
Tuesday, December 22nd, 2009 AT 3:46 AM
Recommended Guides
