1997 Chevy Tahoe oil pressure switch
OHHCHICO
  • 1997 CHEVROLET TAHOE
  • V8
  • 124,000 MILES
Service manual states the oil pressure switch is a secondary circuit for the fuel pump (not activating when ign is turned on), I cannot locate the switch on engine block. I found a switch (or sensor?) On pass side, just above oil pan. When I loosened it, coolant came out. Is this the oil press switch or something else and where is the oil pres switch located?
Do you
have the same problem?
Monday, March 31st, 2008 AT 10:06 AM
RHALL77
Are you trying to figure out why your fuel pump is not turning on? The switch is at the top back of the block by the distrubitor.
Monday, March 31st, 2008 AT 10:22 AM
OHHCHICO
Yes, f/pump is not turning on. I've checked fuse and relay, both good
Monday, March 31st, 2008 AT 10:33 AM
RHALL77
Are you getting voltage to the fuel pump?
Monday, March 31st, 2008 AT 10:41 AM
Recommended Guides
