1996 Chevy Tahoe Grinding noise
STEPHMARIE
  • 1996 CHEVROLET TAHOE
Transmission problem
1996 Chevy Tahoe V8 Four Wheel Drive Automatic
when in motion there is a grinding noise coming from the transmission. It seems to be the transfer case. If you out it in nutral and put it in 4l and the put it in drive then back to neutral and put it back in 2 wheel drive it stops this noise from happening. What could be the cause of this and what needs to be replaced amd or fixed?
Do you
have the same problem?
Saturday, December 12th, 2009 AT 7:36 AM
PEAR69
It sounds like the transfer case actuator motor.
Tuesday, December 22nd, 2009 AT 4:05 AM
Recommended Guides
