Remove door panel. Disconnect connector to window motor. Check power and ground at connector with test lamp. If you have power then replace window motor. Also check window regulator cables. At dealership it is only about $20 extra to get window motor and regulator assembly. If you do not have pwr. And grd. At connector for motor let me know and I will give things to check next.
SPONSORED LINKS
Monday, July 20th, 2009 AT 8:58 AM
