1999 Chevy Suburban Not starting
DRAQ4
  • 1999 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 150,000 MILES
I have a 99 Suburuban that will not start unless you pour a small amount of gas in the throtle body. I have replaced fuel filter, cap and rotor and fuel pump relay. The fuel pump does turn on and once running it idles and revs up like a normal engine. If you shut the vehicle off and immediately turn on again it starts, give it five to ten minutes and it will not start again unless add gas to throtle body again. What are your thoughts?
Do you
have the same problem?
Thursday, January 15th, 2009 AT 10:53 AM
JESSEJAMES405
Check the fuel Pressure regulator its probly bad
Wednesday, January 21st, 2009 AT 10:07 PM
Recommended Guides
