1998 Chevy Suburban driveline noise
MESMONKEY
  • 1998 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 130,000 MILES
A friend of mine has a suburban which emits a whine when the accelerator is released at higher speeds.
I drove the truck to 50 mph and released the pedal. A high pitched whine was audible. As the speed decreases, so does the pitch of the whine. It is audible until the trucks speed drops to about 20 mph.
I don't believe it's the tires since I can hear the tires
noise and it is of a different pitch.
The pitch does not undulate but increases or decreases with the vehicle speed. There is no vibration either.
The vehicle also shifts smoothly between all gears.
I was told all fluids were recently checked and they are all O.K. Although I haven't had a chance to check them myself.
Do you
have the same problem?
Saturday, November 28th, 2009 AT 12:41 PM
  • EXPERT
Does the sound change when you make turns?
Sunday, November 29th, 2009 AT 9:26 PM
Recommended Guides
