1994 Chevy Suburban Brake Pull
DWG
  • 1994 CHEVROLET SUBURBAN
  • V8
  • 87,000 MILES
It has a slight pull to the left when you just touch the brakes?I had a complete brake job done by the dealer at about 62000 miles for the same problem but worse. They said I had a calapsed brake line, I have 25000 on these brakes now and just noticed this doing it now? Thanks
Do you
have the same problem?
Monday, July 13th, 2009 AT 2:16 PM
2CEXPT
BRAKES PULL TO ONE SIDE Caused by contaminated linings, misadjusted brakes, a bad wheel cylinder or caliper, dragging brakes on one side or loose wheel bearings. Can also be caused by a mismatch of friction materials side-to-side on the front brakes or differences in rotor thickness, type or condition
Monday, July 13th, 2009 AT 2:20 PM
