FUEL FILTER?
TIM FLACK
  • 1998 CHEVROLET SUBURBAN
  • V8
  • 225,000 MILES
Where is the fuel filter .I am changing the fuel pump. Truck acts like it is out of gas./Should I also change the fuel line for the fuel pump? Can recommend a quiet fuel pump. Thank you tim
Monday, July 26th, 2010 AT 9:56 PM
Here is a guide to help walk you through the steps of changing the fuel pump and fuel filter which is on the pump with instructions in the diagram below to help you change it out on your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Tuesday, July 27th, 2010 AT 3:36 AM
TIM FLACK
Please answer my questions as I presented them to you. The truck has 225k on it and I didnt think putting 300 into it was really an expense at all. The fuel pump has never been changed and the filter only once. No pressure test required as it acts as if it running out of gas as I drive. Start-up are as if there is gas at all. Easy to define the problem without testing.
I am seeking a quieter runnning fuel pump. BUt would like the best one also. The hoises that I referred to are only the ones from the pump itself to itys juntions. Flexible hoses.. Can you recommend a desired fuel filter?
Thank You.
Tim Falck
Wednesday, July 28th, 2010 AT 11:07 AM
If you owned this vehicle originally and it didn't come with the noise, I recommend only OEM parts.
Wednesday, July 28th, 2010 AT 3:21 PM
TIM BRYANT
  • 1997 CHEVROLET SUBURBAN
  • V8
  • 350,000 MILES
The gas filter under the driver seat has two steel lines going into this can. On the end of the steel lines (both of them --they have an o-ring. I had AutoZone and O'reily's tell me that it does not need these. I afraid I do not believe them. How is right and if needed to I need to go to the dealer.
Monday, September 7th, 2020 AT 1:31 PM (Merged)
Hi Tim,
I am not sure what o-rings you are referring to. Can you get a picture and that will help explain? I am not aware of any so I would think they are correct. I attached the process and they don't mention them either.
OCEANER
  • 1995 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 150,000 MILES
Where is the fuel filter located on the gasoline engine
Monday, September 7th, 2020 AT 1:32 PM (Merged)
The fuel filter is located on the driver side under the passenger door on the inside of the frame. Here is a guide
MIKESHURTE
  • 1994 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 215,000 MILES
Change fuel filter
FIXITMR
  • 9,990 POSTS
Sure, bring it over with lots of beer!
FIXITMR
  • 9,990 POSTS
Should be under drivers side along frame rail and a couple wrenches should do the trick.1 to hold filter nut and the other to break line loose/unscrew.
CATFISH71
  • 1991 CHEVROLET SUBURBAN
Engine Performance problem
1991 Chevy Suburban Four Wheel Drive Automatic 250000 miles
i have a 6.2 litre diesel. I changed the fuel filter and mechanical fuel pump and have fuel to the pump and filter but it still wont start. What should I do
BLUELIGHTNIN6
  • 16,542 POSTS
Check fuel pressure to ensure there are no restrictions. If pressure is OK then check spark at the plugs, make sure it is bright blue spark.
CATFISH71
How and where do I check the pressure. Also I have glow plugs not spark plugs
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry didn't realize it was diesel.
Test the glow plugs first
Pull the electrical connector wires off to expose access to the glow plugs. Removing one plug at a time, place the socket over the top of the glow plug and turn it counterclockwise to remove.
Clean the threads of the glow plug with solvent and a rag.
Set your voltmeter to "Ohms" (Ã ©) and touch the electrodes of the voltmeter to the glow plug.
Check to see if the resistance shown on the meter indicates "Ã ". If it does, then the plug is defective. If the glow plug shows resistance that is approximately less than 5 Ã ©, then the plug is not defective.
Repeat above steps for each glow plug.
CATFISH71
Before I changed the fuel filter and fuel pump it was running rough
BLUELIGHTNIN6
  • 16,542 POSTS
Was the check engine light coming on or staying lit? So it was running prior to replacing pump?
CATFISH71
No the check engine lite wasnt on, yes it was running prior to changing filter and pump
TONISLUG
  • 1986 CHEVROLET SUBURBAN
  • 120,000 MILES
Are you able to describe the entire process of replacing the manual fuel filter on an 86 chevy suburban.
Monday, September 7th, 2020 AT 1:33 PM (Merged)
  • 52,797 POSTS
I assume you mean the gas filter
you need a 13/16 open end wrench and a 5/8 line wrench to remove the lines from the filter.
Be carefull of the fuel that will come out. Use protection on your hands and saftey glasses.
TONISLUG
I meant fuel pump.
