Heater will not work
DRSTEEL
  • CHEVROLET SILVERADO
92 8 cyl stand trans
I can not figure out why the heater will not blow out
heated air.I have checked the hoses, they are ok
Do you
have the same problem?
Wednesday, November 28th, 2007 AT 11:58 PM
YENDY2
Check the thermostat in the engine, if hot water is not circulating through the engine, it is not circulating through the heater core either.
Tuesday, December 11th, 2007 AT 9:54 PM
JIGSTICK
There is a solenoid that is mounted to the back wall of the engine with a air hose attached to it that opens a gate to allow the hot water to get to the heater core. I replaced this in my 96 Tahoe and it solved my no heat problem.
Wednesday, December 12th, 2007 AT 7:42 PM
Recommended Guides
