2008 Chevy Silverado Thermostat size
TNRANDY
  • 2008 CHEVROLET SILVERADO
  • 6 CYL
  • 45,000 MILES
The thermostat on my engine stuck closed and had to be replaced. I replaced it myself with a thermostat from autozone. They did ask what degree I needed and I did not think to ask about that. I put the new one in and now the truck runs cooler than normal. I've owned it since new and it has always ran 210, now with the new stat it runs cooler. The box is stamped 170. Should I replace it with one hotter, and if so what degree? Do they make a 210?
Thanks
Do you
have the same problem?
Monday, August 23rd, 2010 AT 9:59 AM
TNRANDY
Found it. OEM Specs 195
Monday, August 23rd, 2010 AT 1:18 PM
Recommended Guides
