2005 Chevy Silverado high temp and heat not working
WAGNER7911
  • 2005 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 45,000 MILES
My truck normally runs at 200-210. The temp has been reading high (235) but often varies and will go as high as 250 but will then return to 210 stay there for awhile and go back to 235. While the temp is reading higher than normal the heat doesnt work. Then when the temp returns to 210 the heat kicks in. What is the problem
Do you
have the same problem?
Thursday, November 11th, 2010 AT 9:53 AM
FIXITMR
Sounds like air in system? Interrupting heater flow. Raising temp in head.
Friday, November 12th, 2010 AT 6:50 AM
FIXITMR
Possible head gasket compression leak?
Friday, November 12th, 2010 AT 6:54 AM
