2004 Chevy Silverado service 4X4 display
ROD1992
  • 2004 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 80,000 MILES
4x4 drive push button. Sometimes works, sometimes don, t
Do you
have the same problem?
Friday, December 4th, 2009 AT 10:12 PM
  • EXPERT
When it doesn't work, I need you to check to see if there is power to the actuator on the side of the transfer case. If there is power, chances are the actuator needs replaced. If no power, check wiring and harness. Follow wiring back until you find power and the problem. (Could be switch too)
Monday, December 7th, 2009 AT 10:43 AM
Recommended Guides
