2004 Chevy Silverado OIL PRESSURE
JOJO1218
  • 2004 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 160,000 MILES
OIL GAGE READS 0
Do you
have the same problem?
Tuesday, January 12th, 2010 AT 9:18 AM
TOOOMANYTOYS
The oil pressure might not be the issue. In most cases if it reads zero oil pressure all the time, and there is oil in the vehicle the gauge cluster maybe faulty. A way to test it would be to get a manual oil pressure gauge from the auto parts store. Locate the oil pressure sensor (usually near oil filter) Remove sensor and install gauge. If oil pressure is around 20 to 40 psi. Then you have an electrical issue.
Tuesday, January 12th, 2010 AT 9:28 AM
Recommended Guides
