2004 Chevy Silverado Brakes apply themselves
ROCKSTEW1
  • 2004 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 54,000 MILES
What could cause the brakes on my vehicle to become pressurized to the point that the vehicle will stop without applying the brake pedal? I replaced the right front caliper while doing a brake job. And after that the problem began. The brake pedal will become very stiff, and the brakes will lock up.
Do you
have the same problem?
Monday, June 7th, 2010 AT 4:41 PM
DENNYP
  • EXPERT
Try bleeding the brake system. This is going to require the use of a Tech2 scan tool to perform the automated ABS bleed procedure. All of the air must be removed from the system.
Monday, June 7th, 2010 AT 11:15 PM
