2003 Silverado Left door will not operate
JOEARIZONA
  • 2003 CHEVROLET SILVERADO
My 2003 Silverado has a problem with the passangers door. It is all electric & nothing will work(door locks, window, elec. Mirror) the whole door is dead, can I get some help
Do you
have the same problem?
Tuesday, January 9th, 2007 AT 12:46 PM
JDL
  • EXPERT
Sorry for the late reply.
Can you operate passenger door from master switch on driver door? I'd have to check wire harness going into passenger door, hinge side of door. The wire harness usually has a protective rubber boot covering. Pull the boot back far enough to access proper color wire for the system you want to check, voltage and ground.
I can't rule out the master switch.
Friday, March 20th, 2015 AT 2:29 PM
Recommended Guides
