2003 Chevy Silverado instument panel
NIGHTHAWK_ELITE
  • 2003 CHEVROLET SILVERADO
  • V8
  • 4WD
  • MANUAL
  • 40,000 MILES
On a 2003 silverado diesel how do you get the instrument panel back to English. I lost the book that came with it
Do you
have the same problem?
Thursday, August 20th, 2009 AT 3:56 PM
MERLIN2021
  • EXPERT
DRIVER PERSONALIZATION Memory Seat Programming Perform the following actions in order to program the memory seats for 2 separate drivers. Both outside mirrors and the radio station presets can also be programmed with the seat position: 1. Move the seat to the desired position. Include the recliner, lumbar, and side wing area seat position. 2. Press the correct memory seat button for the specific driver and hold for 3 seconds. After pressing the switch a double chime should be heard. 3. Repeat the steps for the second driver. Easy Exit Seat Programming Perform the following actions in order to program the memory seats for 2 separate drivers: 1. Press the correct memory seat button for the specific driver. The seat will move to the last stored memory position. 2. Move the seat to the desired exit/entry position. 3. Press the exit button and hold for 3 seconds. After pressing the switch double chime should be heard. 4. Repeat the steps for the second driver. Programming Features with the Driver Information Center To Enter programming with the DIC, perform the following actions: 1. Turn ON the ignition with the engine OFF. 2. Ensure that the vehicle is in PARK or that the park brake is applied. 3. Press the personalization button on the DIC to scroll through all of the personalization options. Automatic Locking/Automatic Unlocking Continue with the following steps in order to program the automatic door locks feature: 1. The DIC displays LOCK DOORS: OUT OF PARK, MANUALLY or WITH SPEED. 2. Press the select button in order to scroll through the above choices. 3. Press the personalization button in order to select the displayed choice and to advance to the next option. 4. The DIC displays UNLOCK: ALL IN PARK, ALL AT KEY OUT, DOORS MANUALLY or DRIVER IN PARK. 5. Press the select button in order to scroll through the above choices. 6. Press the personalization button in order to advance to the next option. Remote Activation Verification Continue with the following steps in order to program the remote activation verification feature: 1. The DIC displays REMOTE LOCK FEEDBACK: HORN, LAMPS, BOTH, or OFF. 2. Press the select button in order to scroll through the above choices. 3. Press the personalization button in order to select the displayed choice and to advance to the next option. 4. The DIC displays REMOTE UNLOCK FEEDBACK: HORN, LAMPS, BOTH, or OFF. 5. Press the select button in order to scroll through the above choices. 6. Press the personalization button in order to select the displayed choice and to advance to the next option. Headlamp Delay Continue with the following steps in order to program the headlamp delay feature: 1. The DIC displays HEADLAMP DELAY: OFF 10 SEC, 20 SEC, 30 SEC, 60 SEC, 120 SEC, or 180 SEC. 2. Press the select button in order to scroll through the above choices. 3. Press the personalization button in order to select the displayed choice and to advance to the next option. Perimeter Lighting Continue with the following steps in order to program the perimeter lighting feature: 1. The DIC displays PERIMETER LIGHTING: ON or OFF. 2. Press the select button in order to scroll through the above choices. 3. Press the personalization button in order to select the displayed choice and to advance to the next option. Seat Position Recall Continue with the following steps in order to program the memory position recall feature: 1. The DIC displays SEAT POSITION RECALL: ON REMOVE, AT KEY IN, or OFF. 2. Press the select button in order to scroll through the above choices. 3. Press the personalization button in order to select the displayed choice and to advance to the next option. Easy Exit Seat Continue with the following steps in order to program the exit position recall feature: 1. The DIC displays SEAT POSITION EXIT: ON or OFF. 2. Press the select button in order to scroll through the above choices. 3. Press the personalization button in order to select the displayed choice and to advance to the next option. Curb View Assist Continue with the following steps in order to program the Mirror Reverse Tilt feature: 1. The DIC displays CURB VIEW: PASSENGER, DRIVER, BOTH, or OFF. 2. Press the select button in order to scroll through the above choices. 3. When the vehicle is shifted into REVERSE and the Mirror Reverse Tilt feature is activated, any adjustments made to the preset position now becomes the new set position stored, this feature can be customized for each driver. 4. Press the personalization button in order to select the displayed choice and to advance to the next option. Alarm Warning Type Continue with the following steps in order to program the alarm warning feature: 1. The DIC displays ALARM WARNING: HORN, LAMPS, BOTH, or OFF. 2. Press the select button in order to scroll through the above choices. 3. Press the personalization button in order to select the displayed choice and to advance to the next option. Display Language Continue with the following steps in order to program the alarm warning feature: 1. The DIC displays DISPLAY LANGUAGE: ENGLISH, FRENCH, OR SPANISH. 2. Press the select button in order to scroll through the above choices. 3. Press the personalization button in order to select the displayed choice and to advance to the next option. Display Units (ENG/MET) Continue with the following steps in order to program the display units: 1. The DIC displays UNITS: ENGLISH or METRIC. 2. Press the select button in order to scroll through the above choices. 3. Press the personalization button in order to select the displayed choice and to advance to the next option. Exit Programming The following actions end the programming session: The ignition is turned OFF. The programming timer of 15 seconds expires. The personalization button is pressed until the DIC scrolls through all of the personalization options. Print this for future reference!
Thursday, August 20th, 2009 AT 4:09 PM
Recommended Guides
