2002 Chevy Silverado started to idle rough than shut off wi
  • 2002 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 122,000 MILES
Truck was idling and I notice it starting to run rough and then it shut off.
things I check were
1. For the fuel pump working (it is)
2 pressure at the fuel rail (there is)
3 spark at the plugs (there is)
4 check for engine codes ( none)
when trying to start it with no throttle it hits but does not start
Do you
have the same problem?
Tuesday, October 5th, 2010 AT 11:17 AM
Check the fuel pressure if its within specs
Tuesday, October 5th, 2010 AT 11:18 AM
Recommended Guides
