2002 Chevy Silverado Fuel Pump
DIPSTICK
  • 2002 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 152,000 MILES
Engine quit at stop light with no apparent reason. While replacing fuel filter. With fuel filter removed. Cycled ignition key a few times. No fuel from pump. Took 16oz ball-peen hammer and thummped on bottom of fuel tank 10-15 times. Cycled ignition key again. Fuel pump now pumping fuel. Installed new fuel filter and connected lines. Have driven 200 miles with no issues. Shall I keep running the truck w/ my hammer under the seat or replace the fuel pump. Recommend factory pump or after-market which requires wire splices to the factory harness. Factory pump is about 125 more than after- market.
Do you
have the same problem?
Monday, March 30th, 2009 AT 11:58 AM
Replace the fuel pump with an OEM parts
Monday, March 30th, 2009 AT 1:49 PM
Recommended Guides
