2001 Chevy Silverado trans problem
CARL BAKER
  • 2001 CHEVROLET SILVERADO
  • V8
  • 110,000 MILES
Down shift problems shifts up fine and also throttle
position error code will throttle position sensor be
a problem with down shift.
Do you
have the same problem?
Wednesday, January 7th, 2009 AT 11:02 AM
DENNYP
  • EXPERT
The tps can affect the transmission operation. What is the code number you have?
Thursday, January 8th, 2009 AT 11:32 AM
CARL BAKER
Im recieving a p0122 code, thanks for your help
Thursday, January 8th, 2009 AT 1:27 PM
DENNYP
  • EXPERT
DTC P0122
Circuit Description
The throttle position (TP) sensor is used by the powertrain control module (PCM) to determine the throttle plate angle for various engine management systems. The TP sensor is a potentiometer type sensor with three circuits; 5-volt reference, low reference, and signal. The PCM provides the TP sensor with a 5-volt reference circuit and a low reference circuit. Rotation of the TP sensor rotor from the closed throttle position to the wide open throttle (WOT) position provides the PCM with a signal voltage from less than 1 volt to greater than 4 volts through the TP sensor signal circuit. If the PCM detects an excessively low signal voltage, this DTC will set.
Conditions for Running the DTC
" Ignition is ON.
" DTCs P1635 or P1639 are not set.
Conditions for Setting the DTC
" TP sensor signal voltage is less than 0.15 volts.
" The above condition is present for longer than 1 second.
Action Taken When the DTC Sets
" The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
" The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
" The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
" A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
" A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
" Clear the MIL and the DTC with a scan tool.
Test Description
The number below refers to the step number on the diagnostic table.
Malfunctioning components that share the TP sensor 5-volt reference circuit could cause a low voltage condition on this circuit.
DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage Step
Action
Values
Schematic Reference: Engine Controls Schematics
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, observe the TP voltage parameter.
Does the scan tool indicate that the TP sensor voltage is less than the specified value?
0.15 V
Go to Step 4
Go to Step 3
3
Observe the Freeze Frame/Failure records data for this DTC.
Turn OFF the ignition for 30 seconds.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text or as close to the Freeze Frame/Failure Records data that you observed.
Does the DTC fail this ignition?
Go to Step 4
Go to DTC P1121
4
Turn OFF the ignition.
Disconnect the TP sensor harness connector.
Connect a fused jumper wire between the TP sensor 5-volt reference circuit and the TP sensor signal circuit at the TP sensor harness connector.
With a scan tool, observe the TP sensor voltage parameter.
Does the scan tool indicate TP sensor voltage is at the specified value?
5 V
Go to Step 11
Go to Step 5
5
Disconnect the fused jumper wire.
With a DMM, test for voltage between the 5-volt reference circuit of the TP sensor and the low reference circuit of the TP sensor.
Does the DMM indicate voltage near the specified value?
5 V
Go to Step 9
Go to Step 6
6
With a DMM, test the TP sensor 5-volt reference circuit for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
Go to Step 7
7
Test all 5-volt reference circuits for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 14
Go to Step 8
8
With a DMM connected between the TP sensor 5-volt reference circuit and the TP sensor low reference circuit, observe voltage while disconnecting all sensors, one at a time, that use a 5-volt reference signal. A change in voltage indicates the faulty component. Replace that component as necessary. Refer to the appropriate replacement procedure.
Go to Step 14
Go to Step 10
9
With a DMM, test the TP sensor signal circuit for an open, high resistance, or short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 14
Go to Step 10
10
Inspect for poor connections at the PCM harness connector. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 13
11
Inspect for poor connections at the TP sensor harness connector. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 12
12
Replace the TP sensor. Refer to Throttle Position Sensor Replacement.
Did you complete the replacement?
Go to Step 14
13
Replace the PCM, refer to Powertrain Control Module Replacement.
Go to Step 14
14
Use the scan tool in order to clear the DTCs.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run and pass?
Go to Step 15
Go to Step 2
15
With a scan tool, observe the stored information, Capture info.
Does the scan tool display any DTCs that you have not diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Friday, January 9th, 2009 AT 11:50 AM
CARL BAKER
Thankyou for your help,
I still need to id and locate the sensors with 5 volt
ref. Im not getting any voltage at the tp sensor at
any three pins. According to the enfo you sent me
I could hav a shorted sensor or wire harness.
Thanks again Carl Baker
Thursday, January 15th, 2009 AT 6:44 AM
Recommended Guides
