2001 Chevy Silverado
EMT18967
  • 2001 CHEVROLET SILVERADO
Electrical problem
Hello have a 01 silverado that the headlights are not working correctly on. When on low beam one of the hi beams come on and one of the low beams. When on hi beam the lights are all dim. Have checked the ground wire and appears to be good. Voltage at the lamp isn't right. Any Suggestions?
Do you
have the same problem?
Thursday, April 16th, 2009 AT 5:04 PM
JAMES W.
What is the voltage at the headlights. If the lights are dim, 50% brightness, you have a ground.
Do you have "daytime running lights?
Do you have "auto-on" lights? (Come on by themselves at dusk)
It deninately sounds like a bad ground. Even a shorted filiment in a lamp will cause this.
http://www.2carpros.com/forum/automotive_pictures/248092_silverado_lights_1.jpg
Thursday, April 16th, 2009 AT 6:08 PM
Recommended Guides
