Oil Change Message Reset
MICHJMILLER
  • 2000 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 164,200 MILES
How do you reset the message center after an oil change so that it doesn't keep telling you "change engine oil soon"?
Do you
have the same problem?
Wednesday, May 21st, 2008 AT 9:25 AM
KEN
  • ADMIN
Turn the key on without starting the engine. Press gas pedal to the floor five times within 10 seconds. Then shut the key off and you are all set. Start the vehicle, you may need to do this a few times if it doesn't work the first time.
Cheers, Ken
Tuesday, January 2nd, 2018 AT 6:52 PM
FORCES_90
  • 2003 CHEVROLET SILVERADO
  • 164,993 MILES
My truck was running literally 5 minutes ago I forgot something at the house I put it in reverse backed into the parking spot turn the truck off and went into the house at that point I came back outside and attempted to start the truck it will not start continues to say change oil and oil life reset please help me I need to work tomorrow
Wednesday, January 3rd, 2018 AT 5:44 PM (Merged)
HMAC300
  • EXPERT
Try resetting anti theft. Then check battery for condition including load test.
JAKEHARTUNG
  • 2005 CHEVROLET SILVERADO
  • V8
After changing my oil in my chevy truck is there anything you have to do to reset the oil life display?
DOCFIXIT
  • EXPERT
Key on engine off depress accelerator pedal 3 times slowely oil light will flash it is reset if not repeat
Turn ignition ON, with engine off.
Fully press and release the accelerator pedal slowly 3 times within five seconds. If the CHANGE ENGINE OIL message flashes, the system is reset.
However, if message stays on, it did not reset. Repeat the procedure.
Turn ignition OFF.
If CHANGE ENGINE OIL message comes back on when engine is started, repeat reset procedure.
2CARPROS-ARCHIVES
  • 71,000 MILES
My vehicle is equipped with an after market radio. What is the correct way to reset your oil life? Cannot seem to find the reset button for this. Or the book states " select button ", is it located on the original radio?
  • EXPERT
Key on engine off. Push accelerator pedal to the floor 3 times in 5 seconds.
