2000 Chevy Silverado hard start
GORDON TARRANT
  • 2000 CHEVROLET SILVERADO
Engine Mechanical problem
2000 Chevy Silverado 6 cyl Two Wheel Drive Automatic 241000 kilometers
first start of the day is a hard start warm or cold shop crank and crank and finally fires up.
after first start it runs fine no missing at all.
i shoot some carb cleaner in the throttle body and it fires up right away. No check engine lights come on or anything.
Do you
have the same problem?
Monday, January 4th, 2010 AT 7:45 PM
  • EXPERT
It sounds like low fuel pressure. What I need you to do is check fuel pump pressure. Here is a how to:
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Pay special attention to fuel pressure drop off. THat is when you shut the key. Does the system hold pressure or does it drop quickly?
Thursday, January 7th, 2010 AT 8:41 PM
GORDON TARRANT
Thanks for the advice that, s exactly what it was
Friday, January 8th, 2010 AT 4:30 PM
Recommended Guides
