2000 Chevy Silverado 4 wheel drive
BRANSONSHERMAN
  • 2000 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 160,000 MILES
My four wheel drive stopped working recently. No wierd noises just stopped working. Replaced the electronic actuator but didnt fix the problem. Anyone know what might be the problem
Do you
have the same problem?
Sunday, November 16th, 2008 AT 2:09 PM
DENNYP
  • EXPERT
Are the lights in the switch working?
Monday, November 17th, 2008 AT 3:24 PM
BRANSONSHERMAN
Yes when I put it into four wheel drive the light on my dash works. I think it is something in the case because everything else is working properly
Friday, December 5th, 2008 AT 6:09 PM
DENNYP
  • EXPERT
You will need to have it checked for trouble codes in the transfer case control module.
Thursday, December 11th, 2008 AT 1:23 PM
BRANSONSHERMAN
Ok. I have a hypertech programmer that reads dtc's will it pick it up
Thursday, December 11th, 2008 AT 4:45 PM
DENNYP
  • EXPERT
I can't tell you for sure. I can tell you that a Tech2 scanner will work.
Friday, December 12th, 2008 AT 12:30 PM
Recommended Guides
