1999 Chevy Silverado check engine light
COLLINSDJ7
  • 1999 CHEVROLET SILVERADO
  • 6 CYL
  • 180,000 MILES
Code retreval shows po304, # 4 cycl misfire, changed plugs and wires.( Code present before and after plug and wire change) when I erase code it comes up again some times in a day sometimes a week. And just recently the truck started missing only when starting from a stop. Any suggestions?
Do you
have the same problem?
Sunday, January 4th, 2009 AT 10:24 AM
IMPALASS
  • EXPERT
Hello -
To better assist you please tell me the model of your vehicle. Is it a C1500 or K2500 etc. Also the engine size in liter and the 8th digit of your VIN.
Sunday, January 4th, 2009 AT 11:42 AM
COLLINSDJ7
Yes its a c1500, 4.3 liter, 8th digit is "W" thank you
Sunday, January 4th, 2009 AT 2:10 PM
IMPALASS
  • EXPERT
Hello -
I have attached information from Chevy on this code.
Though this may be the cause I would still check the fuel pressure. You do have 180K on the vehicle and low fuel pressure can also cause this if your fuel pump is not putting out enough.
Your call of course. If you do get the fuel pressure check please let me know what it is.
P Code Charts P0304 Important Information - PIP 3081
Notes
Subject: SES Light and P0300 When Towing, Cruising Uphill or on Hard Acceleration - 4.3 5.0 5.7 accelerate cruise cylinderhead RPO L30 L31 L35 LF6 LU3. DTC P0300 P0301 P0302 P0303 P0304 P0305 P0306 P0307 P0308 PIP3081 - (07/23/2004)
Models: (96-02 Chevrolet Astro) and (96-02 GMC Safari) and (96-00 Old Body Style Chevrolet Suburban) and (96-00 Old Body Style Chevrolet Tahoe) and (96-02 Chevrolet Express) and (96-00 GMC Yukon) and (96-00 Chevrolet Old Body Style C/K Truck) and (96-00 GMC Old Body Style C/K Truck) and (96-02 GMC Savana) and (96-99 P32 Cab and Chassis) and (96-02 Chevrolet S-10) and (99-02 Chevrolet Silverado with 4.3L V-6 Engines (96-02 GMC Sonoma) and (96-02 GMC Sierra with 4.3L V-6 Engines).
The following diagnosis might be helpful if the vehicle exhibits the symptom described.
Condition/Concern:
The vehicle may exhibit a SES Light due to a P0300 and misfire. If the misfire is related to the information below, it will typically happen while cruising uphill, pulling a trailer or on hard acceleration and then stop misfiring shortly after returning to an idle. Typically, cylinders 3, 4, 5 or 6 will be the ones to experience this.
Recommendation/Instructions:
If the P0300 diagnostics did not isolate a concern, the following may help:
Remove the valve cover, valve springs and valve seals on the effected cylinder or cylinders. A small wire tie or rubber bands can be placed in the valve stem keeper groove to prevent the valve from falling into the cylinder. Rotate the valve while moving it up and down in the guide to see if it binds. If a binding valve is found, remove both cylinder heads and use either of the following methods to increase the stem to guide clearance:
" Send the head out to a machine shop and advise them to increase the valve stem to guide clearance to 0.002 inch per guide.
" Hone the guide with a 9 mm hone, such as Snap On BCG249, until a clearance of 0.002 inch is obtained. This will usually take about 4 strokes of the hone.
Reassemble the cylinder heads using new valve seals.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
NOTE: GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
Sunday, January 4th, 2009 AT 9:25 PM
Recommended Guides
