Check out the diagrams (Below). Please let us know what you find.
Images (Click to make bigger)
SPONSORED LINKS
Tuesday, May 31st, 2016 AT 9:54 AM
DAVID7158
MEMBER
1997 CHEVROLET SILVERADO
213,150 MILES
When I put a load on and take it to 2,500 to 3,000 rpm's and let shift the engine bogs out and barely has enough power to move at 25 mph. Engine will completely shut off at this point if I open the throttle too far. This whole problem resolves itself if I park the truck and turn off for about ten to fifteen minutes.
Thursday, September 3rd, 2020 AT 12:30 PM
(Merged)
MECHANIC
Good afternoon,
This could be a couple of things.
Low fuel pressure from a weak fuel pump. The pressure needs to be checked.
(Merged)
DAVID7158
MEMBER
Okay, thanks. I will look into it.
(Merged)
MECHANIC
Keep us updated.
SPONSORED LINKS
(Merged)
DAVID7158
MEMBER
This problem started after I replaced my rotor and cap. I forgot to include that.
(Merged)
MECHANIC
Okay, start with verifying you installed it correctly.
(Merged)
DAVID7158
MEMBER
It should be. I put it back the way it came off. I did break the front screw thread so I got a c clamp on it.
(Merged)
MECHANIC
Do the other checks.
(Merged)
DAVID7158
MEMBER
She has low fuel pressure and I don't know why cause I replaced everything in the fuel system injectors, pump, sending unit, fuel filter, the injectors came with a pressure regulator. The injectors are the mpfi upgrade over the sfi ones
(Merged)
MECHANIC
What is the fuel pressure?
(Merged)
DKLEIN
MEMBER
1 POST
4 CYL
4WD
AUTOMATIC
99,999 MILES
When accelerating normal everything is fine, but if I tromp down regardless of speed it slows down and almost dies out the tach doesnt jump like the trans. Is slipping but almost as if its dumping out
SPONSORED LINKS
(Merged)
DENNYP
MECHANIC
I dont recall a 4cyl in a silverado. Whatever it may be, you should check your fuel psi. If it's dropping off a lot under hard accelleration, you might have a bad fuel pump.
(Merged)
DAVID7158
MEMBER
22 to 23 psi.
(Merged)
MECHANIC
What motor is in the truck?
(Merged)
DAVID7158
MEMBER
5.7 350.
(Merged)
MECHANIC
Okay, Te specs are below.
Your pump is not working at all.
Fuel Pressure
Central SFI. 60-66 psi
SFI. 56-62 psi
(Merged)
DAVID7158
MEMBER
Okay, so pump is garbage then.
(Merged)
MECHANIC
Yes, that is correct.
(Merged)
DAVID7158
MEMBER
Okay, thanks.
(Merged)
