1996 Chevy Silverado engine misfire
SDGUNTER200
  • 1996 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 130,000 MILES
Ihave a engine misfire code on cyl. #5. I replaced the cap rotor plugs And wires. I still have the same problem.I have ckecked for vaccum leaks and found none. Injectors have been replaced five k ago.I have run injector cleaner which did not help. It runs worse at idle under load when it is cold. Iwould like to know which sensor to check next.
Do you
have the same problem?
Tuesday, April 21st, 2009 AT 9:44 PM
  • EXPERT
Have you checked the compression in that cylender?
Sunday, April 26th, 2009 AT 12:25 PM
Recommended Guides
