1996 Chevy Silverado Antilock brake system
OLEHEART
  • 1996 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 101,000 MILES
Antilock brakes sometimes comes to work even on dry pavement works okay on ice cover with somewhat more extra pressure. Pull the 60 amp brake fuse @ ABS light comes on @ can lock up brakes. It's got me stumped.
Do you
have the same problem?
Tuesday, February 3rd, 2009 AT 6:55 PM
JACK42
When you pull the fuse, you disable the ABS system and make it standard brakes, that is why the light is on and they will lock up. Has the light ever come on when it is malfunctioning? Does it do this over bumps or train tracks? A scan of the ABS system may be in order to see if the computer saw a failure and stored a code
Wednesday, February 4th, 2009 AT 8:02 AM
