1994 Chevy Silverado wont stay running
ROBBIE LAMB
  • 1994 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 140,000 MILES
Truck wont stay running fuel pump is good replaced coil but it dies when you start it any ideas you can give me?
Do you
have the same problem?
Tuesday, May 11th, 2010 AT 1:40 PM
INTERNETMECHANIC
How long since a tune-up? Use a gage and check fuel pressure specs. Any applicable trouble codes? Will it stay running, if you open the throttle a little? Maybe an idle air issue? No code diagnostics list for start and die, is about as long as your arm. I can post it if you want? You need something to point us in the right direction, otherwise, just speaking for myself, it is hunt and peck.
Tuesday, May 11th, 2010 AT 4:10 PM
Recommended Guides
