1994 Chevy Silverado ENGINE HEAT GAGE NOT WORKING
KAVANCE
  • 1994 CHEVROLET SILVERADO
Engine Cooling problem
1994 Chevy Silverado V8 Two Wheel Drive Automatic
HEAT GAGE STOPPED WORKING.
CHANGED SENDER ON TOP OF ENGINE AND CHANGED
TERMISTAT. STILL NOT WORKING. GAGE SHOWES
COLD ALL THE TIME.
HELP
KEN SNYDER
Do you
have the same problem?
Tuesday, May 18th, 2010 AT 8:42 AM
DWB812
I'm pretty sure the sender on that is a single wire at the driver's side front of engine down by the exhaust manifold. It can get heat damaged and the connector can get an intermittent or, as in your case, a dead open condition. Make sure you replacced the correct sender/connector. To test it put the wire to ground and the gaufe should peg out.
Tuesday, October 19th, 2010 AT 2:28 PM
DWB812
Gauge, and peg out to the left.
Tuesday, April 19th, 2011 AT 9:03 AM
Recommended Guides
