1989 Chevy Silverado truck stalls
CHEVYMETRO19
  • 1989 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 18,500 MILES
My truck will start and idle fine when in park you can even reav it and it will run fine but as soon as you put the truck in gear the truck will stumble and stall
iv replaced the o2 sensor the fuel filter and I just resentle put new headers on it why does the truck stumble and stall when in gear
Do you
have the same problem?
Friday, April 3rd, 2009 AT 5:03 PM
Check the TPS, MAF, and MAP sensor to include the EGR valve
Friday, April 3rd, 2009 AT 5:11 PM
WA
Same issue here what did your problem end up being? I have changed the TPS sensor, injectors, fuel regulator, plugs, wires, cap, rotor, coil, runs/idles strong but then put into gear and it stalls out. Any ideas would be great thanks. 1990 Chevy Silverado 350 V8 5.0L
Monday, May 23rd, 2011 AT 4:15 AM
Check the exhaust system for restriction
Wednesday, May 25th, 2011 AT 5:01 AM
Recommended Guides
