2002 Chevy S-10 will not start when hot
OLDEDAYS
  • 2002 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 137,000 MILES
My engine starts fine when cold (fuel pump works), but after it runs and gets to normal hot temperature, and I shout it off, it will not start (and the fuel pump will not come on either, there is spark at the coil).
Do you
have the same problem?
Thursday, September 17th, 2009 AT 3:53 PM
  • EXPERT
When you turn key to run do you hear the fuel pump come on for a few secs, if not check fuel pump fuse and fuel pump relay if so check the fuel pressure if its within specs.
Friday, September 18th, 2009 AT 5:18 AM
