Fuel pressure regulator location?
ANONYMOUS
  • 2003 CHEVROLET S-10
  • 122,000 MILES
Where is the fuel pressure regulator located on a 2.2 engine
Wednesday, October 24th, 2012 AT 4:07 PM
DOCHAGERTY
  • 9,601 POSTS
The fuel pressure regulator is located On the end of the fuel rail where the lines attach. Couldn't find any real good pics of the location. See the diagram below, the regulator is on the end of the fuel rail where #3 attaches.
FUEL FILTER/FUEL PRESSURE REGULATOR
The fuel filter/fuel pressure regulator is located on the fuel feed pipe, between the fuel pump and the fuel injectors. The paper filter element traps particles in the fuel that may damage the fuel injection system. The fuel filter/fuel pressure regulator housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. Replace the fuel filter/fuel pressure regulator if the filter is restricted.
The fuel pressure regulator is a diaphragm relief valve. The fuel pressure regulator maintains a constant pressure differential across the fuel injectors at all times. A software bias compensates the injector on-time because the fuel pressure regulator is not referenced to manifold vacuum. The injector pulse width varies with the signal from the Manifold Absolute Pressure (MAP) sensor.
Wednesday, October 24th, 2012 AT 4:27 PM
IRVGOODWIN
  • 2002 CHEVROLET S-10
  • 6 CYL
  • 15,000 MILES
Trying to locate fuel pressure regulator on chevy s-10 pick-up truck
Sunday, October 7th, 2018 AT 8:04 PM (Merged)
JDL
  • 16,098 POSTS
Hello, if you have the spider fuel system, you have to remove upper intake manifold, to get at it.
SLDRCHRIS85
  • 1991 CHEVROLET S-10
  • 6 CYL
  • 69,700 MILES
I need to know if there is any special way that I have to replace the fuel pressure regulator
Tuesday, April 16th, 2019 AT 6:19 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Properly relieve the fuel system pressure and disconnect the negative battery cable.
Disengage the vacuum line from the pressure regulator.
If applicable, disengage the fuel line(s) from the regulator.
Remove the retaining bolts, then separate the regulator from the fuel rail assembly.
https://www.2carpros.com/forum/automotive_pictures/261618_1_122.jpg
To install:
Install the regulator to the fuel rail and secure using the retaining bolts.
If applicable, engage the fuel line(s) to the regulator.
Engage the regulator vacuum hose.
Connect the negative battery cable, then pressurize the fuel system by cycling the ignition (without attempting to start the engine) and check for leaks.
