2000 Chevy S-10 will not start
JOHN61945
  • 2000 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 96,000 MILES
I have a chevy s10 that will not start, turn the key and i'll get one to three clicks from the starter solnoid and i'll loose all power today just screwing around with power up to the radio and inst I pressed the 4wd button lost all power press down on the door lock switch and the temp gauge moves after a two to three times trying to start no power at all to anything
Do you
have the same problem?
Sunday, October 11th, 2009 AT 11:20 PM
F4I_GUY
  • EXPERT
What is the condition of your battery? I would start off by giving the ground and power cables a good look over for any corrosion. Next I would check to see if my starter solenoid is recieving and signal when I go to crank the vehicle. If there is no signal, you will have to back track as to why. If there is a signal you may have a faulty ground wire, or a faulty starter.
Wednesday, May 3rd, 2017 AT 11:11 AM
